Sinumerik Alarm 10942 Channel %1 block %2 curve table %3: illegal instruction during definition
%3 = Number of curve table
Various illegal command sequences cause the output of this alarm during the definition of the curve table. For example, it is impermissible to terminate definition of a curve table with M30 before programming the CTABEND command.
Correct the part program and start it again.
