Seco Thread Turning Wizard
Seco Thread Turning wizard will help you to select the correct products for your thread turning application, calculate the optimum cutting data and generate a part-program.
Free to download Seco thread turning wizard is available for both Metric an Inch systems.
The Seco Thread Turning Wizard makes threading easy and enables you to select holder, insert and optimum cutting parameters, improves accuracy thread tolerances and chip control and reduces cycle time and improves tool life.
Related: Other Free Downloads from Seco tools
- Secolor Turning Calculator by SecoTools Free Download
- Seco Tools Assistant Mobile App for CNC Machinist
- Seco Tools Catalogue pdf Download Free aka Seco Machining Navigator Catalogue
Why to use Seco Thread Turning Wizard?
- Simplify programming
- Makes threading easy
- Selects holder, insert and optimum cutting parameters
- Improves accuracy thread tolerances and chip control
- Reduces cycle time and improves tool life
