Okuma Alarm-D 4718 Invalid parameter setting
The value set at the turret rotation range parameter is larger than the value set at the parameter for specifying the number of turret tools. Or, the range 1 set value is larger than the range 2 set value.
1->A wrong value is set for A-turret rotation range 1.
2->A wrong value is set for A-turret rotation range 2.
3->Data on turret B rotation range 1 is wrong.
4->Data on turret B rotation range 2 is wrong.
5->The following condition is not met: Rotation enabled range
1 =< rotation enabled range =< Rotation enabled range 2
6->The ZB-axis range where the turret B can rotate is wrongly set.
7->The following condition is not met: Chuck A close position
< Chuck A clamp position < Chuck A open position
8->The following condition is not met: Chuck B close position
< Chuck B clamp position < Chuck B open position
9->1st spindle,
The following condition is not met: Chuck open position
< Chuck grasp diameter < Chuck close positionOr,[+/- OK] have entered [NG area].
10->2nd spindle,
