Okuma Alarm-B 2536 Coordinate movement rotation copy
G11/G10/COPY/COPE command is wrong.
1->G11/G10/COPY/COPE command is designated though the Coordinates movement rotation copy specification is not provided.
2->It instructed in G11 as follows.
NO G17 Mode
COPY mode
Multi cycle mode
Lap mode
During the cutter radius compensation mode (Nose radius compensation mode)
NO Y axis mode
G127-mode
G99-mode
G117-mode
G155-mode
G265-mode
3->It instructed in G10/COPYE as follows.
Multi cycle mode
G11-mode [G10 Only]
4->It instructed in the G11/COPY mode as follows.
G11 [COPY Only]
G15/G16
G18/G19/G119
G20/G21/G24/G25
G30
G31-G35
G80-G88
G98/G99
G101-G103
G107/G108
G112/G113
G117
G127
G132/G133
G136
G140/G141
G265
5->It instructed in Q with G178/G179/G181-G184/G190-G191 in the G11/COPY mode.
6->The side face machining was instructed in with G178/G179/G181-G184/G190-G191 in the G11/COPY mode.
7->It instructed Q instruction instructing in COPY excluding 1-9999.
It instructed Q instruction in two or more in the MDI mode.
8->It is parallel and the rotation movement and is not instructed in the done axis by the first axis movement instruction after it instructs in G11/COPY/G11/COPYE about coordinates.
Incorrect program
Correct the program.
