Okuma Alarm-B 2533 Steady rest over interference pos.
Command for Steady-rests, Tail stock or W-axis to exceed the interference position.
Axis
1-> Right steady-rests interference area (minimal distance).
2-> Left steady-rests interference area (maximum distance).
3-> Left steady-rests interference area (minimal distance).
4-> Right steady-rests interference area (maximum distance).
1)Program error.
2)Interference range parameter is not correctly.
1)Check the movement command of the axis.
2)Set the interference range parameter correctly.
