Okuma Alarm-B 2417 MULTI-MACHINING CYCLE I,K
In G181 through G184 and G189 mode cycle, both I and K or neither I nor K is designated. (I,K shift amount)
In G181 through G184 and G189 mode cycle, designated I and K values are not: 0 <= I, K <= 99999.999, 0 <= J <= 99999.999In G185 through G188 mode cycle, designated I and K values are not: -99999.999 <= I, K <= 99999.999G181: Drilling cycleG182: Boring cycleG183: Deep hole drilling cycleG184: Tapping cycleG189: Reaming, boring cycleObject
None->Both I and K commands are designated.
1->I or K command are designated during M964 is effective.
FFFFFFFF->I or K command is omitted.
Others->Hexadecimal number of I and K values
Faulty program (compound fixed cycle block)
Program Example:
G181 X60 Z75 C0 F40
Check the I or K command in the compound fixed cycle block.
G181 X60 Z75 C0 K48 F40
Related Specifications
Multi-machining model
