Okuma Alarm-B 2397 MULTI CYCLE I,K over
In the G73 and G74 grooving cycle, the parameter of I or K is greater than the allowable value causing negative groove depth.
G73: Compound grooving cycle on side face
G74: Compound grooving cycle on end face
I: For taper thread, a radial difference between start and end points should be entered (radius command).
For taper thread, either A or I value should be specified.
K: For taper thread, a difference between start and end points should be entered.
Program error
Program Example:
N009 G00 X100 Z100
N010 G73 X50 Z50 I60 K10 D10 L25 F0.2
Check the I command value in the G73 mode, and K command value in the G74 mode.
For the example program, correct the I command value since it is greater than the target value.
N010 G73 X50 Z50 I6 K10 D10 L25 F0.2
