Okuma Alarm-B 2313 UGC Expression
Expression syntax error
1->More than one solution
2->Program end code in expression
3->Operand stack area over
4->Mismatch between the numbers of operands
5->Operand classification code stack area over:Mismatch between the numbers of left brackets “[” and right brackets “]”.
6->More than two subscript expressions
Substitute statement and quadratic expression in the user graphic command
Program Example:
PS LL,[0,0],[100,100,100],4
Check and correct the syntax of substitute statement and quadratic expression.
Related Specifications
Graphic
