Okuma Alarm-B 2058 Error occurred while CAS work
The instruction not used while CAS works.
1-> M64 and M65 were instructed in.
2-> M110/M109 and XZW axis rapid feed was instructed in the same block, in case of the operation time reduction function II was effective (NC optional parameter bit No.11 bit3=1).
3-> M220, M221, M222, M223, M224, M225, and M226 were instructed in.
4-> The home position instruction to which the movement order was set was instructed in.
5-> M153 was instructed in.
6-> G101 was instructed in.
7-> G21 was instructed in by switching off Y axis mode.
8-> G24 was instructed in.
9-> M110 (C axis connection) was instructed in after workpiece transfer without M151 comannd.
Please transfer a workpiece in M151 mode when you use C axis instruction after workpiece transfer.
A-> M66 (Turret indexing position free) was instructed in.
The turret index sequence must be executed on programmable limit.
B-> The G00 function of Y axis and Z axis was instructed in to the same block in the G136 mode.
C-> M556 was instructed in.
D-> G265, G255 is effective
E-> G266 was instructed in.
F-> In Steady rest ZB axis control specification, There are instructions other than M122 (Or, M123) in the block in which it instructs in M122 (Or, M123) on A saddle side. Please instruct one block only in M122 (Or, M123) when instructing in M122
10-> G149 was instructed in.
11-> G117 was instructed in.
12-> C axis rapid feed and XYZW axis rapid feed was instructed in the same block.Because the rapid feed movement of C axis and a straight line axis simultaneously is not the linear interpolation operation, correct interference detection cannot be done. Therefore, this alarm is generated.
This alarm might be generated in the block in which C axis is not instructed either because the change of the internal instruction value of C axis is checked.
14-> There are instructions other than DRAW, CASCME, CASCTL in the block in which DRAW, CASCME, CASCTL was instructed.
15-> Tool breakage detection sensor instruction (M698/M699), and the turret index are instructed in the same block.
16-> Invalid external HP instruction.
17-> G149 was instructed in.
In case of collision check way between A turret and B turret was chosen BARRIER.(2-saddle model)
18-> Effective steady rests to open/close and 2-saddle model, There are instructions other than M78 (Or, M79, M121) in the block in which it instructs in M78 (Or, M79, M121) on A saddle side. Please instruct one block only in M78 (Or, M79, M121) when instructing in M78 (Or, M79, M121) on A saddle side.
Expected faulty point
There is an instruction that cannot be used while CAS engine works. Please confirm the NC program.
Treatment measures
Please release the Collision Avoidance function by switching off (CAS parameter or M instruction) when you want to execute the instruction.
However, interference is not detected in that case and drive, please after it confirms it enough.
In case of code=12, After it is confirmed not to interfere, bit 2 of NC optional parameter bit No.62 is set to “1”.
The NC program can be executed without correcting the NC program because alarm B becomes alarm D.
