Okuma Alarm-A 8604 Long tool change protection
1->The cover open/close command is designated while the spindle is rotating.
2->The cover open/close command is designated when the M-tool spindle is rotating.
3->The cover open/close command is designated when the C-axis is rotating.
4->The cover open/close command is designated while the turret is not at the travel end of Z-axis
5->The cover open/close command is designated when the slider was not retract position.
6->The slider advance/retract command is designated when the cover was not open position.
7->The gripper open/close command is designated when the slider was not advance/retract position.
8->The ATC command(M06,M288,M321,M421) is designated when the Long tool was the turret tool.
11->The cover was not closed position during Spindle rotation.
or, Spindle rotation command was designated when the cover was not closed position.
12->The cover was not closed position during M-spindle rotation. or, M-spindle rotation command was designated when the cover was not closed position.
13->The cover was not closed position during C-axis movement.
or, C-axis movement command was designated when the cover was not closed position.
14->The cover was not closed position during axis movement.
or, axis movement command was designated when the cover was not closed position.
15->The cover was not closed position during turret indexing.
or, turret index command was designated when the cover was not closed position.
16->The tool exchange command was issued with the tool exchange preparation not completed.
17->The long tool loading command was issued with a tool installed in the turret or the object tool not registered on the long tool information screen.
18->The long tool unloading command was issued with the standard tool installed in the turret or a tool not installed in the turret.
19->M axis clamp command was issued when the M-spindle was rotating or the M-spindle was not orientated state or turret was not ATC place divided state.
20->The long tool loading answer signal was not input within setting value of parameter after the long tool loading command has been executed.
21->The long tool unloading answer signal was not input within setting value of parameter after the long tool unloading command has been executed.
