Okuma Alarm-A 8509 Cutting feed interlock
The command of cutting-feed was performed by the state that cutting-feed was impossible, or the condition of cutting-feed turned off during cutting-feed.
None->Concerning “L-tool Index” specification of H1 turret for MacTurn, the command of cutting-feed was performed by the state that was not “M-tool spindle clamp angle 0”, or “M-toolspindle clamp angle 180” when L-tool or sensor is registered with present-tool.
1->Concerning ATC specification machine type, the command of cutting-feed was performed when the ATC tool is not exist
(the no tool signal is on).
2->Concerning ATC specification machine type, the no tool signal is turned on while cutting feed.
3->Concerning H1 turret specification machine type, the command of cutting-feed was performed when M-tool spindle is not clamped.
4->Concerning H1 turret specification machine type, M-tool spindle clamp confirmation is turned off while cutting feed.
5->Concerning H1 turret specification machine type, the command of cutting-feed was performed when the turret is not curvic clamped.
6->Concerning H1 turret specification machine type, the turret curvic clamp confirmation is turned off while cutting feed.
7->A cutting-feed command was issued, when a long boring bar tool was mounted and a auxiliary tool was not mounted in the turret H1.
1)The state of “M-tool spindle clamp confirmation input”.
2)Program error
3)The state of “The turret clamp/unclamp confirmation input”.
1)Check the state of “M-spindle clamp confirmation input”.
2)When it was not the state of “M-tool spindle clamp angle 0”, or “M-tool spindle clamp angle 180”, do not order the command of cutting-feed on program.
3)Check the state of “The turret clamp/unclamp confirmation input”.
