Okuma Alarm-A 1788 Safety door open
At the time of automatic operational mode/MDI operational mode selection, a side cover or a back surface cover is not close status.
A side cover or a back surface cover is not close status at the time of a main spindle rotation condition by Manual Operation
Mode/manually operated interruption.
A reference block cover for measure within a machine or a cleaning window is not close status.
1->Concerning automatic operation/MDI operation mode, when reference block cover for measure within a machine was not closing, it chose a tool except for sensor-in a cutting position and performed a sending axis movement order.
2->They went along a main spindle rotation order by the condition which opened a door for regulation of chuck opening and shutting limit SW.
Or, it became the condition that a door for regulation of chuck opening and shutting limit SW is not close in main spindle rotation.
3->When a ATC maintenance cover was not close, ATC moved.
Or, the order which makes ATC act was performed.
4->When a ATC maintenance cover and ATC shutter was not close main spindle, M tool spindle, axis moved.
Or, a ATC maintenance cover and ATC shutter was not close during main spindle rotation, M tool spindle rotation, axis movement.
5->A spindle rotation command was issued when the loader safety cover was not closed, or the loader safety cover was not closed during spindle rotation.
6->The ceiling door open/close command was ued, when turret was rotation instruction was performed by the state which attached measure sensor to turret for M tool securing pin.
7->The cleaning cover for magazine is not close.
