Makino Pro 3 G Codes (Fanuc 16i/18i)
Makino Professional 3 CNC Control (Makino Pro 3) G Code list for cnc machinists who work on CNC machines with Makino Pro 3 (Fanuc 16i/18i ) CNC controls.
Makino Pro 3 CNC Control
Makino Pro 3 G Code
G CodeFunction
G00Rapid Positioning
G01Linear Interpolation (Feed Rate)
G02Circular/Helical Interpolation CW
G03Circular/Helical Interpolation CCW
G04Dwell
G05High Speed Remote Buffer Operation
G07.1Cylindrical Interpolation
G09Exact Stop Check
G10Data Setting
G11Data Setting Mode Cancel
G12.1Polar Coordinate Interpolation Mode
G13.1Polar Coordinate Interpolation Mode Cancel
G15Polar Coordinate Command Cancel
G16Polar Coordinate Command
G17X Y Plane
G18Z X Plane
G19Y Z Plane
G20Inch Input
G21Metric Input
G22Stored Stroke Check Function On
G23Stored Stroke Check Function Off
G25Spindle Speed Fluctuation Off
G26Spindle Speed Fluctuation On
G27Reference Point Return Check
G28Automatic Reference Point Return
G29Return From Reference Point
G30Return To 2nd, 3rd, 4th Reference Point
G30.1Floating Reference Return
G31Skip Function
G33Thread Cutting
G37Tool Length Automatic Measurement
G39Cutter Radius Compensation Corner Rounding
G40Cutter Radius Compensation Cancel / 3 Dimensional Tool Comp. Cancel
G41Cutter Radius Compensation Left / 3 Dimensional Tool Comp. Left
G42Cutter Radius Compensation Right / 3 Dimensional Tool Comp. Right
G40.1Normal Direction Control Cancel Mode
G41.1Normal Direction Control Left Side On
G42.1Normal Direction Control Right Side On
G43Tool Length Compensation + Direction
G44Tool Length Compensation – Direction
G45Tool Offset Increase
G46Tool Offset Decrease
G47Tool Offset Double Increase
G48Tool Offset Double Decrease
G49Tool Length Compensation Cancel
G50Scaling Cancel
G51Scaling
G50.1Programmable Mirror Image Cancel
G51.1Programmable Mirror Image On
G52Local Coordinate System Setting
G53Machine Coordinate System Selection
G54Work Coordinate System 1 Selection
G54.1Additional Work Coordinate System Selection
G55Work Coordinate System 2 Selection
G56Work Coordinate System 3 Selection
G57Work Coordinate System 4 Selection
G58Work Coordinate System 5 Selection
G59Work Coordinate System 6 Selection
G60Single Direction Positioning
G61Exact Stop Mode
G62Automatic Corner Override Mode
G63Tapping Mode
G64Cutting Mode
G65Macro Call
G66Macro Call A
G67Macro Call A/b Cancel
G68Coordinate System Rotation
G69Coordinate System Rotation Cancel
G73Peck Drilling Cycle
G74Counter Tapping Cycle (Left Hand Tapping)
G76Fine Boring Cycle
G80Canned Cycle Cancel / Ext. Operation Function Cancel
G81Drilling Cycle, Spot Boring / Ext. Operation
G82Drilling Cycle, Counter Boring
G83Peck Drilling Cycle
G84Tapping (Right Hand Tapping)
G85Boring Cycle
G86Boring Cycle
G87Back Boring Cycle
G88Boring Cycle
G89Boring Cycle
G90Absolute Command (Position)
G91Incremental Command (Positioning)
G92Absolute Zero Preset
G94Feed Per Minute
G95Feed Per Revolution
G96Constant Surface Feed Control
G97Constant Surface Feed Control Cancel
G98Canned Cycle Initial Level Return
G99Canned Cycle R Point Level Return
