Haas Setting 114 115 Conveyor Cycle Time – Conveyor On-time (Minutes)
Haas Setting 114 Conveyor Cycle Time (Minutes)
Haas Setting 115 Conveyor On-time (Minutes)
Haas Setting Description
These two settings control the optional chip conveyor. Setting 114 controls how often the cycle is to be repeated, and Setting 115 specifies the number of minutes the conveyor will run. For example, if Setting 114 is set to 30 and Setting 115 is set to 2, the chip conveyor will turn itself on every half hour (30 minutes), run for two minutes, then turn itself off.
