Haas Parameter 835 AXIS MINIMUM FALL DELAY
Used with Grease Reservoir type “3” in parameter 810. Specifies the minimum wait time in milliseconds for the grease pressure to remain high after turning air OFF to lube system. If the input pressure falls within this fall delay, air might be in the grease line or the pressure input switch is bad.
