Haas Parameter 834 AXIS MINIMUM RISE DELAY
Used with grease reservoir type 3 in parameter 810. Specifies the minimum wait time in milliseconds for the grease pressure to rise after turning air ON to the lube system. No grease pressure should rise prior to this time delay. If pressure was detected within this period, air might be in the grease line or the pressure input switch may be shorted.
