Haas Parameter 813 AXIS PRESSURE TIME
Specifies the minimum stable high pressure detection time in milliseconds during axis lubricant discharge. The control will display the LOW LUBE message if the system does not sustain pressure for the specified duration. A “0” value means no time limit for pressure. A value of zero is required for type ‘2’ (Parameter 810) lube systems. A nonzero value is required for type ‘3’ lube systems.
