Haas Parameter 810 AXIS LUBE TYPE
Specifies the axis lubrication system type.
  • 0 BATTERY axis (OM1A/OM2A) or Manual (SR’s/TM’s) lube
  • 1 BIJUR oil system. The values in parameters 811 through 816 will be inactive.
  • 2 Minimal Lubrication system (Grease Gun). The values in parameters 811 through 816 will be active.
  • 3 Minimal Lubrication system (Grease Reservoir). The values in parameters 811 through 816 will be active.
