Haas Parameter 79 SPINDLE STEPS/REV
Sets the number of spindle encoder steps per revolution of the spindle. This number takes into account the pulley ratio between transmission and spindle, plus transmission and encoder. If there are 2 encoders employed, this number applies to the encoder on the spindle (connected to the SP input of the mocon). If only 1 encoder is employed, it will be for that encoder. In most installations, the single encoder will be mounted on the motor but will still connect to the SP input of the mocon.
