Haas Parameter 732 IPS PROBE – Haas Mill
The operator can use the intuitive probe screens, on a Tool Room mill, with the IPS feature activated, a probe, and this parameter set to 1. These screens (displays) are within the setup tab, and are used to calibrate both the work and tool probe. The user can probe the length and diameter of the tools during set up. This feature allows probing of the work piece to set up the work zero offset. Refer to Engineering Document ES0566 – Intuitive Probing.
