Haas Parameter 721 ‘RUNNING’ RELAY
Supports the Machine Data Collection feature which specifies output relay to be turned on when machine is in Running mode. This only works when set to 32 or larger, specifies an actual relay, and Parameter 315, bit 26, Status Relays is set to zero. If Single Block is activated while machine is running, relay may not turn off at end of current block.
