Haas Parameter 708 PALLET CHANGER AXIS
Specifies the MOCON channel of the MDC-1 and EC-300 pallet changer. It enables both the servo axis pallet changer and the Super SMTC tool changer to operate on the same machine. On an MDC-1 with a single MOCON board, this parameter must be set to 4. On an MDC-1 or EC-300 with two MOCON boards, this parameter must be set to 8. On all other machines, this parameter must be set to 0. Note also that when set to 4, B-axis parameters are used to control the pallet changer and the message “Use Tt Params” is displayed. When this parameter is set to 8, the W-axis parameters are used to control the pallet changer.
