Haas Parameter 693 STEADY REST INPUT – Haas Lathe
Supports the steady rest option. If a lathe has the option and a foot pedal for the steady rest, it must be set to the input relay number for the foot pedal switch. This number can be 1 through 49 for relays #1101 through #1049, respectively. For lathes without a steady rest foot pedal, this parameter should be zero.
