Haas Parameter 601 TOOL CHANGE DELAY – Haas Mill
On a mill where the operator must be warned that a running program doing a tool change (no enclosure) it beeps and delays for the duration specified by Parameter 601. If Parameter 601 is set to zero, there will be no beep or delay. If the operator changes tools by pressing buttons on any kind of tool changer, there will be no beep or delay. If the machine has a manual tool changer and M06 is commanded from a running program, there will be no beep or delay. The control will stop and prompt the operator to manually insert the tool.
