Haas Parameter 298 MAX FEED (DEG/MIN) – Haas Mill
Used on 5-axis mills. Maximum rotary feedrate in degrees per minute. Any attempt at cutting faster than this will result in “LIM” being displayed next to the Feed message on the Program Command Check screen. On mills with a gimbaled spindle, this parameter must be set to 300. For all other mills,it should be set to 99999.
