Haas Parameter 292 AUTO DOOR PAUSE – Haas Mill
Supports the Auto-Door feature. It specifies the length of a pause (in 50ths of a second) that occurs during the door close sequence. As the door closes and the switch is activated, the motor is turned off for this amount of time and the door coasts. This allows the door to close smoothly. It works in conjunction with Parameter 293.
