Haas Parameter 259 COLD SPINDLE DAYS – Haas Mill
The first time Cycle Start is pressed after the machine is turned on, the control will compare the number of days that have passed since the machine was turned off against the value of this parameter. If the machine has been off longer, the control will assume that the spindle is too cold or inadequately lubricated to be run safely at high speed and the following message will be displayed:
!!!WARNING!!!
YOUR MACHINE IS COLD, RUN A WARM-UP PROGRAM BEFORE RUNNING THE SPINDLE AT HIGH SPEED
OR DAMAGE MAY RESULT
PRESS ‘CANCEL’ TO CONTINUE
The user must press CANCEL before continuing. It is recommended that a spindle warm-up program be run immediately. This message will only appear once each time the machine has been turned on. The initial value for this parameter is 3 (days). To disable this feature, change it to 999999.
