Haas Parameter 257 SPINDL ORIENT OFSET
If equipped with spindle vector drive (as set in bit 7 of Parameter 278), this bit sets spindle orientation offset. The offset is the number of encoder steps between Z pulse and correct spindle orientation position. It is used to orient the spindle properly anytime it needs to be locked, such as prior to a tool change, or orient spindle command.
