Haas Parameter 252 TAIL ST. OVERLOAD – – Haas Lathe
Determines overload limit when the tailstock is traveling in the minus direction, toward the spindle. It is an arbitrary value based on effective voltage being sent to the tailstock servo motor. If too low, you may not be able to move the tailstock. Increase the value until you are able to move the tailstock. It is used for ball screw tailstock or TL-15.
