Haas Parameter 213 B TOOL CHANGE OFFSET – Haas Mill
Sets the distance between the B-axis grid offset (Parameter 170) and the spindle home position. The B-axis will be limited in movement to the area between the positive value of this parameter and the negative Max Travel. This parameter must be used on all mills with the 60 or 120 pocket chain-style tool changer, as opposed to Parameter 215, Carousel Offset, which is used on other side-mount tool changers. Note that on a machine with a single MOCON board, the Tt-axis parameters are automatically copied to the B-axis parameters and only the Tt-axis parameters can be altered.
