Haas Parameter 156 B MAX TRAVEL (Steps)
See Parameter 6 for description. Normally this parameter would not apply to the A axis; however, this parameter is used on mills with a gimbaled spindle (5-axes mills). On a VR-series mill this parameter is used to limit the amount of angular movement of the spindle (A and B axes). The A and B axes are limited in movement to a distance between negative Max Travel and positive Tool Change Offset. On 5-axes mills A and B axes Rot Trvl Lim must be set to 1, Max Travel and Tool Change Offset must be calibrated and set correctly.
