Haas Alarm 924 SS LOW LUBE OR LOW PRESSURE – Haas Lathe
Alarm: 924 SS LOW LUBE OR LOW PRESSURE – Haas Lathe
Way lube is low or empty or there is no lube pressure or too high a pressure. Check tank at rear of machine and below control cabinet. Also check connector on the side of the control cabinet. Check that the lube lines are not blocked. Parameter 616 determines cycle time.
