G Codes GSK983M CNC Milling
G Codes GSK983M S/V Drillling & Milling CNC System
GSK 983Ma CNC Control
G Codes GSK983M
G CodeFunction
G00 Positioning
G01 Linear interpolation
G02 Circular interpolation (CW)
G03 Circular interpolation (CCW)
G04 Dwell
G05 High-speed continuous cutting mode
G07 Federate sine curve control
G09 Exact stop check
G10 Offset value setting, start of registration of tool life management data
G11 End of registration of tool life management data
G17 XY plane selection
G18 ZX plane selection
G19 YZ plane selection
G20 Input in inch
G21 Input in mm
G22 Stored stroke limit ON
G23 Stored stroke limit OFF
G27 Reference point return check
G28 Return to reference point
G29 Return from reference point
G30 Return to 2 nd , 3 rd , 4 th reference point
G31 Skipping cutting
G33 Thread cutting
G40 Cutter compensation cancel
G41 Cutter compensation left
G42 Cutter compensation right
G43 Tool length compensation + direction
G44 Tool length compensation – direction
G49 Tool length compensation cancel
G45 Tool offset increase
G46 Tool offset decrease
G47 Tool offset double increase
G48 Tool offset double decrease
G50 Scaling off
G51 Scaling on
G54 Workpiece coordinate system 1 select
G55 Workpiece coordinate system 2 select
G56 Workpiece coordinate system 3 select
G57 Workpiece coordinate system 4 select
G58 Workpiece coordinate system 5 select
G59 Workpiece coordinate system 6 select
G60 Single directional positioning
G61 Exact stop check mode
G62 Automatic corner override
G64 Cutting mode
G65 Custom macro simple call
G66 Custom macro modal call
G67 Custom macro modal call cancellation
G73 Peck drilling cycle
G74 Counter tapping cycle
G76 Fine boring
G80 Canned cycle cancel
G81 Drilling cycle, spot boring
G82 Drilling cycle, counter boring
G83 Peck drilling cycle
G84 Tapping cycle
G85 Boring cycle
G86 Boring cycle
G87 Back boring cycle
G88 Boring cycle
G89 Boring cycle
G90 Absolute programming
G91 Incremental programming
G92 Absolute zero programming
G94 Per minute feed
G95 Per revolution feed
G98 Return to initial point in canned cycle
G99 Return to R point in canned cycle
